I
IAHawk
How is CarPro Reload used? Do you use before applying a wax or sealant or after and used as a quick detailer?
Can you use CarPro Eraser with a clay? And it is used to prep the surface for polishing and applying a wax or sealant.
What I have done so far is used Iron X, on my vehicle then I washed it. I would plan on polishing it then apply a sealant and wax. Before i do this I need to prep the surface. I was reading the instructions about Reload and tips and you say the surface should be completely clean and free of oil, solvents, or wax before applying Reload.
Thank you
Thank you
