REVIEW: Creeper seat for detailing!
Dr_Pain
I've seen the subject of work stools being tossed around quite a bit lately , and read many opinions and preferences. Obviously I do have some of mine as well. It does seem that the same opinions are tossed around, but no real breakdown comparison is being offered. I would like to take this opportunity to present the subject and interject my opinions in the matter, and would like to present my argument discussing the:
1) Ergonomics
2) Cost
3) Construction
4) and Function
Being a physical therapist by profession I do support heavily the "proper ergonomics" argument, but if you were to ask my "complete" opinion on the subject this post would be a lecture that could get quite hairy. Trust me this review does not need to be that complication since we are all looking for the same thing, that is a cheap, safe and functional tool which we can abused day in day out, and replaced economically (if need be). I've evaluated several seats over the years, from the cheapo Harbor Freight option to the most expensive Kreepstool, and came to an honest conclusion on the subject. Here is what I have tried so far
1) Standard creeper seat (I believe it was from Sears for around $25)
2) An adjustable pneumatic creeper seat (from Harbor Freight for about $25)
3) An adjustable Traxion (purchased online $125)
4) Kreepstool (borrowed valued at $180)
**One I wanted to try before writing this review was the Racatac but at $225, I did not see the value of the investment despite the ergonomics
Without dragging this review let me give you my winner and personal recommendation, that is the Northern Tools "Big Red" seat (made my Torin), which can be purchase for $50 (less if you use the discount coupon). But WHY?? In evaluating all of those seats I evaluated them for cost, function and ergonomics, and I feel the Torin "Big Red" was the best without breaking the bank.
Here is a side by side of 3 creeper seats I have in my shop (two of which are destined for the landfill)
attachment.php
So what makes it a winner??
Construction:
  1. Chrome plated heavy gauge steel square tubing
  2. Plastic tray insert
  3. Allen head flush bolts with lock washer
  4. Sealed bearing 3 INCH wheels
  5. Wide padded seat
  6. Bottle holder/cupholder
  7. Max weight capacity is 400lbs
If I was to expand on the list above this is what I would say about it: It is made of chrome plated steel which will tolerate the constant environmental exposure, regardless if it is sprayed down by accident, or doused in chemicals. A plastic tray insert is provided for tool storage, which won't corrode if water is allowed to sit for days or if you have an inadvertent product spill. The same can't be said about the HF cheapo seat. Unlike some of the more economical seats, this seat uses Allen head bolts which is much better than the cheap nuts which tend to back out with use. Unlike most seats, this particular creeper is set on 3" wheels which are much more functional then the standard 2" which are only rated to 250 lbs. To be honest, the bottle holder is a nice added bonus (and useful) but extremely flimsy. The rest of the seat on the other hand is SOLID. For those questioning the fact that I am not considering an adjustable height seat, let me be honest and say that I NEVER use that function (and neither does most people I spoke to). A backrest would be good, but how many times do we opt to sit in our creeper and lean back on the back rest??? In terms of function the Big Red seat rolls with great ease. It is not as easy as the Traxion to roll over extension cords, but it is definitely better than the five wheel HF cheapo (which every caster tends to go in their own directions <--- what a pain)
At $50 it is almost 2x what I would pay for the HF cheapo, but its value is self evident in the fact that I normally have to replace a seat/year (because the wheel bearings fall apart or gets chewed up so bad). At 6'6" and 235lbs I am close to the max for the cheapos, whereas the Big Red is rated to 400lbs.
As you can see from the pictures included there is no real comparison in the quality. You can also see the quality of the wheels
attachment.php
attachment.php
attachment.php
attachment.php
From the picture you can see there is a slight difference in height between all of them (less than 1"). While detailing, the lower you get the less bending at the waist you have to do, however there comes a point when the position of "knee to chest" (from sitting so low) becomes functionally hindering.
attachment.php
attachment.php
attachment.php
My rear is definitely appreciative of the extra width of the seat but not as much as with the extra padding
attachment.php
attachment.php
Do I have anything bad to say about the seat? Surprisingly I don't. I like its heavy construction, 3" sealed bearing caster (rated for heavy loads); I like the wide, well-padded seat and height. I like the fact that it has a plastic tray and that it is chrome plated for durability. Although the bottle/cup holder is pretty flimsy, it is usable and functional .
So why would I even consider purchasing a Kreepstool for 4x the price, or a Racatac for 5x the price? Well, I would not!!!! The Kreepstool sits too high to do most wheel well and wheel work. It does have a decent amount of storage, but I have a habit of never storing much stuff in my creeper seat because it will invariable get sprayed as I go around the car with the power washer. The seat back is ergonomically preferred (under perfect conditions) but would only be used in very select seated position (for resting). Polishing a panel sitting in the Kreepstool still requires you to lean forward to put the machine on paint and to apply down pressure so the backrest becomes a non-issue.
When selecting a creeper seat, you have to consider its realistic applications, and to be honest I do not see the cost/benefit value of any seat above $50 as they WILL get abused and will need to be replaced. Conversely, you get what you pay for. To decide on a $25 stool from HF which is not rated for normal oversized people makes no sense either. Best to spend a little more and get something you won't have to replace yearly.
Hope you enjoyed my review. Here is a glamor shot of the stool in action over the weekend. Note the CarPro red masking tape which I will review, and the PF2500 (my preferred compound) sitting nicely in the cup holder.
attachment.php
Thanks for taking your time to put up this rather unique review on one of the most essential tools for the professional detailer.
Great job! :)
Thanks for the review! I have actually been looking for a quality affordable stool. This is exactly what I need.
Sent from my phone when I am supposed to be doing something else.
Great job! :)
I agree it is quite a departure from my average product review but as you mentioned it is one of the most essential tool for a professional detailer (and even a weekend amateur)
I knew at least one person would have your reaction. I promise you won't get disappointed. It is a heavy, solidly built seat and one I see lasting for YEARS!! I've debated quite a few time about the "need" for an adjustable seat, but in the end concluded that there are more drawbacks to the piston seats then positives (from instability as you roll around, to piston failure, to the wobbly nature of the seat (only having a center attachment point).
Awesome Claude!! Thanks for taking the time to put this together! A great and most appreciated review to anyone that details... Comfort added tool maybe more important than anything else we use or at least more appreciated! I'm in the market for one!
LOL! Thanks Corey! No need to really do much research. Why don't you come visit and try it first hand :)
Thanks Claude for this AWESOME review and all the great pictures! I've read it and re-read it about 3 times and you sold me on it; I bit the bullet and ordered one today!
Congratulation on your purchase. I seriously doubt you will be disappointed in your purchase. If you were to come to my shop you will see that the count is now 2.... and may soon grow to 3 ;)
Want to say thanks again for this review. I now have one on the way.
Well, I have had my stool for a couple of weeks now. I must say that it is as expected based on the review. It rolls effortlessly, doesn't deform like the cheaper ones do and the cup holder fits the round bottles of polish/sealant nicely. While I was shopping, I decided to spring for a service cart to hold other detailing items (you guys are a bad influence according to my wife). Before these, I sat on a bucket and rested my polisher on one too. The other products were always on a counter at the front of my garage which required a lot of walking back and forth. These two items have made detailing so much more efficient and enjoyable. Thanks again for the stool review!
I've had the stool for 4 months now and could not be any happier. I have to say thought that the flimsy cup holder is not being used as much as I thought I was going to use it, but that retrospect realization would not have detracted me from purchasing the stool. Still a 2 thumbs up purchase in my book! No more HF cheapo stools for me
I have had mine for a little over a year now and must say it was a great investment. It looks and works as well as when I bought it. The casters are very durable.
Sent from my SAMSUNG-SM-N900A using Tapatalk
I purchased mine direct from Northern Tool. $49 plus shipping...I received it it a few days.
So far, I'm really liking this stool! An excellent investment.
Thank you for helping me spend money and improving my quality of life.
Dr_Pain - Per your review I just ordered one.
I'm looking forward to its arrival!
Thought I'd follow up with some thoughts...
Per Dr_Pain's review I purchased the chrome Torin. I've used it and abused it for years now and it still works and looks good as new.
The only bad thing is that the Torin is not adjustable height wise. For that I still need to use my $25 ($20 on sale) HF pneumatic stool.
attachment.php
So far, I have only had one HF pneumatic stool that gave up the ghost. When you sit on the stool it slowly sinks down to the bottom.
This happened after years of use and abuse. So for $20 I went and got a new one. It's not solid like the Torin but it goes up and down.
