The Guz
Member
I had received this as part of a giveaway
https://carproforum.com/showthread.php?4609-OBSSSSD-product-giveaway!
Product Description:
I finally had the opportunity to use it. Unfortunately I will not be able to update with a longevity or durability update as my brother has put this car up for sale. I am also located in Southern California and don't see harsh weather conditions and I would expect that this paint sealant would last most of the year (roughly 6-8 months)
It does come in a nice bottle with a matte label.
Description and instructions on the rear of the label.
Consistency is thinner than other sealants I have used. I did give it a good shake for about a minute which did thicken it some. It comes out of the opening of the bottle rather quickly. I tried to capture it on the foam applicator but it was absorbed pretty quickly. I applied it by hand.
The car was one step polished and sealed with Obssssd paint sealant. Application was straight forward as my brother and I split the car in half and put a thin coat. We let it sit for the recommended time although being in So Cal the sealant was ready to be removed sooner than the recommended time.
Wipe off was a breeze.
It left the paint slick and with a nice shine. I can't say it is close to a carnauba but it does look good. Especially on this polished red paint.
Perhaps if we added another coat it would have given a wetter look. But our goal was to get it ready for sale.
After curing overnight, I sprayed the paint with water from a spray bottle. Beading looks nice and tight. I did not get a video but the sheeting looked really good as well.
Final Thoughts:
Overall I found this to go on rather easily. It was easy to wipe off. It left the surface slick and with a nice shine.
The initial beading and sheeting looks good. As mentioned I will not be able to provide updates once the car is sold off.
It can be purchased here. Give it a try.
https://www.carpro-us.com/latest-arrivals/obssssd-paint-sealant-16-oz/
OBSSSSD™ Paint Seal Final Protectant is the perfect sealant to protect a daily-driven vehicle in all weather conditions. OBSSSSD Paint Seal has been developed to provide an exceptionally deep, wet-looking shine for months while protecting from harsh road salts, oxidation, and detergents. Paint Seal provides superior protection from harsh environmental elements and ultraviolet radiation utilizing the latest next generation polymer technology.
Note: Avoid contact with plastic, vinyl, and rubber as staining may occur. If contact occurs, remove immediately using a damp microfiber towel. Do not use in direct sunlight.
Key Benefits:
ECO Friendly & Bio-degradable
Durable
Provides durable UV protection
Leaves slick, non-stick finish
VOC compliant
Instructions:
For neglected or oxidized surfaces, first use a polish appropriate for the severity of the paint damage. Use OBSSSSD™ Paint Clean for newer paints or surfaces that require light preparation.
Shake well before use.
Make sure the surface is cool, clean, and dry.
Apply 2 dime-sized amounts to a clean dry foam applicator and rub thoroughly onto the surface to create a thin film.
Allow 15 minutes or more for the sealant to dry. This allows proper bonding to occur.
Use a dry microfiber towel, buff until residue is gone.
For an even deeper, wetter-looking shine, apply additional layers after 6 hours.
OBSSSSD™ Paint Seal can also be applied using a dual-action polisher equipped with a soft foam pad.
Recommended Surfaces:
Clear coated surfaces
Painted surfaces
Final Thoughts:
