Sema 2017
Cooter
Administrator
Hey guys. We'll be at SEMA again this year. Booth #12749. Please come by and see us if you get a chance!!!Corey, Wes, Thomas, Timo(Madness guys)and myself will be there all week. There's no telling who else will be there.
Be sure to check out the Bug-Out!!!
I don't know what else is being released as of yet. I'm in the Houson airport at the moment waiting on a connecting flight to Vegas!!!
Viva La SEMA!!!!!
There will be a couple of new products released today!! Word on the Bug-Out is already out there. Look for something to be clearly different released today!!
Some interesting new products. Per instagram.
Very exciting, Mike! Christmas is early this year!
Posted on the CarPro Facebook page
The Gliss - FAQ and more details
Here are some FAQ and details about the Gliss, this is something we worked in the past year, many detailers asked us for a top coat, something that excels the ceramic coat which applied already. from smoothness to hydrophobic contact angle. a coat which resist better water spots and has better anti static effect. yet not to use organic oils or waxes , while yet to have longer slickness compare to oily waxes or siloxanes sealants,(we will post soon comparison video to show how its durable). it wasnt easy to do and took us time, we hope we succeed and made it well, GLISS can be used as stand alone coat as well, for quick application cars. application is super easy as you saw maybe how we demo here at Sema . full dry time is shorter as well , ( by IR is super fast too)
SOME FAQ'S about Gliss :
-What Gliss means? Gliss in Franch means very slick surface.
-Is Gliss perform as sealant or a coat? its more a coat with much more durability against chemicals.
-Can it be used on top of Reload , Essence, Essence Plus ? No since it will not bond well over the surface.
-Can you use it on other coating? Probably yes , but we cant guarantee that, with our coatings , as Cquartz Cquartz UK , Cquartz Pro , and the Cquartz Finest Reserve it works perfect with higher contact angle hydrophobic.
-Can you use it as stand alone coat ? Yes its very easy to use and will bond well on bare paint.
-Do you need to use Eraser pre coat ? Only if the surface was waxed or sealed, will need to strip anything such as .
-Can we use Cquartz on top of Gliss ? No since it made to be a topper rather than primer.
-Can we use it over coated car which was done few months already ? Yes its even well recommended.
-Does it get crystallize ?? No , not meant to add hardness as one of its targets was to help protection from water marks. highly sio2 base coats weak point is water spots marking, this is to help protecting from it as well.
-Can we top the Gliss with Reload ? Yes but we dont see any reason why.
-Does Gliss attract dust over the surface? Gliss use inorganic oils to produce slickness , together with Anti static additives it will attract much less dust than most ceramic coat or top coats.
-How much the bottle contain and how many cars we can coat? 50ml with 2~3 average cars coating.
- Can i use TarX on the Gliss ? yes to some extended time , will not remove the coat.
- Durability ? we believe between 6 to 12 months , if well maintained using pH neutral shampoos.
If any of you guys has more questions we'll be glad to answer.
Interesting that it is not recommended to be applied over Essence. Looking forward to trying this out.
