D
Dogrescuer
Hey guys is the paint on Toyotas generally hard or soft? I have a hood to correct tomorrow.
Toyota white and black is prone to fading/oxidation. I did one not long ago with M101 and car pro flash pad followed by reflect and gloss pad. Had great results.
Then thay process should be fineYes that hood is white and oxidized
I have a ES coming in this weekend, black, paint all oxidised.Also remember that some Toyota models (non-metallic, especially white and black) are single stage paint. Toyota's Rav4 particularly comes to mind. Not sure if they're still doing SS paints, but I did a 2004 and a 2006 that were both SS paint. Very easy to correct.
Also remember some Toyota models/paints (non-metallic, especially white and black) are single stage paint (and quite thin). Some of Toyota's Rav4's and some Tundra's particularly come to mind, but definitely not all. Not sure if they're still doing SS paints, but I did a 2004 and a 2006 that were both SS paint. Very easy to correct. As others have mentioned, it's usually not a good idea to generalize rather a paint is hard or soft based on the manufacturer, however I have found most Toyota paints I have worked on to be quite easy to correct. In contrast; I have found most all Corvettes I have worked on to be considerably harder... These are usually the only two paints (other than Porsche paint) I generalize in my mind before actually spinning a pad across them.
I usually generalize these two paints (in my mind, based on personal experience as):
Toyota = Soft
Corvette = Hard
Around here we dont even see Porsche therefore I can only wish that I will ever get the opportunity to work on one.
