Hi all,
I have a BMW 430D 2017 and looking to keep the car in good condition, especially with winter about to start here in the UK.
I have selected the following 2 products due to their ease of applying.
1. TRIX
2. Hydro2
After doing a lot of research I was planning on applying the TRIX to my car while dry with dirt still on it so that TRIX does not run down the bodywork of the car. I was going to do the bodywork and alloys and then let the product work and rinse off with a powerjet.
1. Is TRIX safe to spray onto glass and plastic? I have an M Performance body kit made of plastic and don't want to ruin it.
2. Can I use a soft sponge to spread the product around?
After rinsing TRIX off, I was then going to apply the hydro2 using a contact wash using the Merino wash Mit.
1. Can I just use Hydro2 and wash the car by hand letting the product sit on the car while I go around, or would it be better to wash panel by panel and then rinse off?
Once I have finished rinsing the car down I was going to dry it using a drying microfiber towel.
Is this procedure advisable? Is there anything else I should add in for better results?
Thanks in advance
JD
1. TRIX
2. Hydro2
Thanks in advance
JD
