Wrap a 4" mf Suede around the grey side of applicator block.
Shake CQuartz UK.
Slowly open bottle and drag one or two lines of product down the applicator.
Spread across paint in a criss cross pattern approximately 2 sq ft at a time depending on conditions.
Buff off as soon as it flashes (within 2-5 minutes depending - see tips above) using a CarPro No Lint Ultra Towel 16" x 16".
Be sure to remove all excess residue and only then do you move to the next section.
Switch out the 4" Suedes every 2+/- panels.
Additional coats may be applied with 45-60 minutes or wait until the following day if you are beyond 60 minutes. CarPro recommends 2 coats. Max Layer - 3 coats.
Apply Reload after final coat within 30- 60 mins. Wait until next day for Reload if you miss the 30-60 minute window or at least a minimum of 12 hrs.
Directions: (For use as top coat)
May be applied 4 hours or longer after CQuartz.
If IR cured may be applied after 45 minutes from CQuartz application
Q. Can we top the Gliss with Reload?
A. Yes but it is not necessary. However if you choose to do so Reload can be applied after 12 hrs.
... Finally finished the paint correction and got my 2x layers of cquartz down... Car has been sitting in garage still perfectly clean since coating... My question is, any reason for me to wipe down again with Eraser before I top with my gliss?...
Sorry guys one last follow up question.
Thanks again!
