After I'll coat 2 cars I guess the Lite (150ml) will be over, I'll also gain experience and be ready to the better product
1. Would you recommend sticking to the Lite again?
2. Would UK last even less than Lite if I won't polish?
Thanks1. Yes you can use Reload over Lite. You will just have to chemically strip Reload before recoating. Same thing with hyrdo2.
ThanksI will probably go with CQLite as the 1st Layer. As for the 2nd, I like the simplicity of Hydro2Lite.
I would highly appreciate more info:
1. Will there be a visual benefit in using Hydro2Lite over CQLite? Especially gloss wise. (Maybe I am better off with CQLite alone)
2. What about Reload?
3. Can I skip IPA wipe down before application of CQLite in case a polish won't be needed? (I guess 10% alcohol to be on the safe side with the 20' Mazda3).
Hey Guz, my question would be.......Does Lite require polishing to remove it when recoating with it down the road?
