donbeezy
First white vehicle in the garage since coming back! Sometimes white can be easy going but on this one, a few more problems made it a longer work day. Over spray from under body coating was sprayed all along the driver rear door/quarter panel area. Heavy clay bar and extra loving was needed to remove these unsightly black dots. A long scratch on the rear door was also removed; 3000grit with a small sanding block made quick work to reduce the scratch, removing about .2 mils along the way. Discovered some grey paint drops on the roof, those were carefully razor bladed off and heavy compound. Rest of the vehicle received a heavy 1 step and coated with Cquartz. Enjoy.
