Bad batch of reload?
  • Thread starter Thread starter mikered30
Troy nailed it about pollen... Any coating or sealant will be affected if it is hit with pollen and moisture before it has time to cure. After a product as strong as Reload has cured it will withstand pollen and stuff better than traditional sealants and wax BUT it must be washed regularly. If let to fester on the surface day after day getting moist and then UV cycle after cycle it will affect all products if never washed.
thanks for the answer Corey.
what is the cure time on reload before I expose it to elements?
also, should I let essence cure before I apply reload? if so what is the cure time on essence?
and while I'm at it, if I decide to use hydro2lite as a spray and wipe product? does that need to cure too?
Reload cure is a day but can be released to water within hours.
Yes. - cure essence an hour or longer before using reload
I would personally not use hydroLite as a QD. Reload diluted is better for that
