You’re welcome, Rick!
I prefer to use Reload as a “stand alone” every few months as a topper on my coatings. After the vehicle is washed and dried, I’m applying it to a dry cool surface in a shaded area, I will apply it as per instructions. I have also applied it via a microfiber applicator and let it sit a few minutes then remove. It could be me but I think it leaves the surface slicker.
As a drying agent, Elixir has some Reload in it. Elixir isn’t a full strength Reload application but it will add some protection.
Either way, a shaded area and cool surface. So if you can get that area in the barn squared away...lol
I don’t know if you do this but I will sheet or flood the surface with the hose without a nozzle, I have a shut off on the end. I will allow the water to remove much of the standing water. I then use my Blaster Revolution to remove any remaining water While keeping a drying towel in hand for those crevice areas. The less I can touch the surface the better.
When I do use a drying towel, I will use either ECH2O , mixed to QD ratio, or Elixir. I may use Elixir once a month and ECH2O the other times.
As far as applying Reload, the environmental factors will come into play. I live in South Alabama and the sun is absolutely brutal down here, also the torrential down pours on top of that. Then add in road construction and other fall out from the air.
I “think “ I hit most of your questions, at least I hope so. If I didn’t please let me know.
EDIT....If you use Reload as a Drying agent, you can certainly do that but financially speaking and dilution wise, it is costly.
