Been using Ech2o over CQuartz as both a waterless and quick detailer. Do I need to decon with Reset,TarX and Eraser before applying Gliss?
Any official manufacturer write up coming?
Spring is coming and I am planning on pulling GLISS on our Jetta that has an old coat of CQUK. It has been nearly 3 years. I was hoping to just use Essence to clean up the paint and some minor water spotting. Would I be better to redo the CQ application then use GLISS or just go straight GLISS? I kinda want to go straight Gliss just to get a good durability test since the product is so new.
I have read the recommendations that Gliss needs a clean surface and the using Essences might not work well but I wonder why. If Essence is made to work and be a primer for CQ I don’t see why it wouldn’t do the same for Gliss. So if anyone has the science behind it I am open.
What if I use Essence then give it 12hr cure time then apply Gliss the next day?
It wont affect gliss performance anyway, dont worry mate lolzi hope what you say is true. i have a new car and coated with with quartz uk then gliss. on day one i did wash, iron-x then eraser, then h20/ipa wipe and then coated with quartz uk. waited 36 hours and inspected vehicle closely - zero haze. next i applied the gliss and waited several hours - no haze. after 24 hours inspected again and no haze. car wasn't driven for more than 48 hours after the gliss coat. fast forward 6 days and I've got haze everywhere. car did get wet on day 5 after gliss. i just applied some quick detailer and did light hand buff and at the moment the haze is gone. fingers crossed.
Yes sir! Reset, Iron X, a light Tar X if needed, Reset, good rinse, and eraser.
What if I have yet to coat my vehicle at all, but I have used Ech20 as a QD?
I want to apply Essence, Cquartz, then Gliss, so would you suggest Tar X still?
One question, why you cant use TarX to maintain Gliss just like IronX? Thanks
I am prepping to use the Gliss I have the 1st week in June as I will have all week with the vehicle. I am looking to get options or opinions with pads for applying Essence or Essence Plus. I don't have any Gloss pads but I do have the LC White / Rupes Yellow & White / Megs MF Cut and Finish Disks. I am serioulsy considering the Megs MF Finishing Disks since I want a little bit of cut and clean up but I'm not planning on doing major paint correction.
Truth be told our VW is 10 years old and approaching 200k. I am not sure I will be keeping the car for more than a few years. I think that using the Essence as a base layer will be a good test to also show long term results when used with Gliss.
I personally did not like Essence with a cutting pad. Was hard to remove at times.
Troy, why not throw a coat of CQuartz UK 3 in between the Essence and Gliss? That's what I just did to a 25-year-old Mercury Grand Marquis. UK 3 was very difficult to wipe off with the CarPro suede microfiber, but the newer CarPro two-face towel cut the buff-off time in half.
I have a bottle of Gliss, but have yet to open it up and use it. I am seeing and hearing reviews, saying that you should not overlap due to its nature (maybe the quickness of flashing). When overlapping like a regular coating, Gliss is reportedly not behaving/lasting as long as it should/could. Can you all give some insight on the issue?
