So what is my first step ?
  • Thread starter Thread starter krazygraphics
Damn every day I learn more and I can't complete this project ! I guess I don't know what to do now other than call someone , thanks !
OH and before I forget , does the CQUK protect against sprinklers ? or will I have to use SPOTLESS every few days with reload ? Any ideas would be great , thanks
No coating can protect you from hard water spots. Can you park out of the path of the sprinklers, that would be my suggestion.
I do , problem is if it's windy the mist will land on the car.
So if I do get water spots after CQUK so I just use spotless then reload ?
You may want to consider getting a DA polisher and doing it yourself. With the right DA it really is quite easy and you would have to try really hard to damage anything. You could probably get a a polisher, some pads, and a polish or two for somewhere around a couple of hundred bucks. Then you would have it and could play around when ever you wanted. If this is something you may be interested in, let us know and we will help you select the right stuff for your needs.
Thanks , I may try and do all of this myself. Tomorrow the IronX should arrive in the mail.
