JHZR2
It was 68 degrees without strong sun here in NJ today, so I decided to wash the van. It has Cquartz UK and gets an update of HydrO2 every few times I wash it. I didnt have much time, so I wanted to wash with HydroFoam to give an update good for the rest of the winter.
Because I havent washed in a few months, I wanted to pre-soak the dirt, and since the hydrofoam was in the foam gun, I used that. After all, it was cool and not sunny...
After a few minutes, it looked like the soap had run down the panels in stream/flow lines, with the rest of the area barely wet, and certainly not soapy... I rinsed off fully, and it looed very much like there were lines where the foam had streamed off, with the rest still dull.
Hoping for the best, I then soaped panel by panel, and washed, cleaning the sponge after each panel. I could tell that didnt fix it...
So then I took 3:1 HydrO2, misted it on a panel, agitated it a bit woth a damp sponge, and rinsed off. It didnt help.
So now what? Its like this on the paint and glass...
