What to do and how to do it.
  • Thread starter Thread starter Clarkgriswald
Thanks for the feedback. I'll have to look at one of those wheel woolies that's bent to get behind the face. I'm always afraid to just spray ironx on because I feel rushed to make sure it doesn't dry. What does the ech2o do to help dry? I wonder if the next time I wash my truck if it will make a difference on how the dryer works with blowing off the water.
Do you dilute reload for a black color? How do you know you have a good coat down?
Well I don't own a black car but you should be able to feel the slickness while applying and removing reload off the surface.
You would be using Ech2o as a drying aid to help with avoiding water spots.
Good video on the incredibrush.
https://youtu.be/OzFfK2ifvw8
Another on the EZ brush.
https://youtu.be/xsXkqhfs-Mc
My truck is coated with CQ Finest. I work right next to the Northeast Rail line corridor. I use Iron X maybe twice a year...
I have both Wheel woolies and Daytona wheel brush in my tool box.
Not necessarily about the Reload. At worst, the Reload mixed 1:1 may not last as long as full strength.
You can do another Reload coat and, unless you park at a railroad yard, no need to IronX again.
Ok good. I just have to figure out how to wash and dry faster. It always seems like my truck dries too fast.
Now that I have the Metrovac I'm hoping that helps especially now that I have reload on the truck.
I have a Crew Max Tundra...it's possible...LOL!
Ok so you know then. :D How do you do it and not feel rushed but not take all day either.
Plenty of shade and a cool vehicle. I have it down to a science. Keeping up on the maintenance routine is key. Admittedly, there are sometimes when it does take me longer due to the dirt level, such as prolonged rainy period, snow, etc...
I get everything set up, three buckets, one for the wheels alone, foam cannon filled, drying devices plugged in and ready. I start with my wheels and tires and go from there. Now when I do a decon regiment then it takes longer.
Each time you do your routine cleaning, look back at where you can tweek things...
I usually do have everything set up ready to go. What do you use to wash the top of your truck? I have a bench that I stand on and wash half then move the bench and wash the other half. That takes time. I'm hoping the incredipole comes out soon because I could use it.
How does using a quick detailer help in the drying process and do you have to use a lot? That wouldn't work for when I want to use the metrovac would it.
I have a large step stool along with a device sorta like the incredi mitt pole from another vendor.
I use an air drying device myself but a q.d adds lubricity to the towel drying process. It "may" also add a small level of protection, depending on which product you use. It may also help reduce water spots in some situations.
Several times I saw guys with a hose washing huge industrial trucks. At first glance, this procedure doesn't look like it can damage the car. Although I'll be honest, I didn't see a washing machine nearby. But the owner of those trucks is my old friend. I know that he has been using these services for several years and has no complaints about the quality of work. Maybe I wouldn't risk washing a sports car or an ordinary family car in the same way. But it's a good option for large rough machines.
